Snorkel for cold air intake?
I got a cold air intake kit installed on the Suburban a couple weeks ago (pictures coming soon) and plan on building an insulated box to avoid heat soak.
I'm wondering if enough air is coming into the area from the hole in the inner fender, so naturally I want more.  From what I see, there is not much room to run a snorkel to the front unless I put it under the passenger side front air dam and that seems low enough that it would suck up an awful lot of road grime, wet air and the occasional cat   :cheers:
Does anyone have ideas for a source of cool air that's somewhat protected from water (and cats)?  Like on other cars, you can put an inlet behind the headlight or somewhere.  On my Caprice I have a great setup that pipes air up from in front of the radiator into a heat-resistant shroud so it gets plenty of air (see My Webpage for pics).  With the Suburban setup this won't work because there's not enough room, but I want access to plenty of air.  I thought about cutting the hood for a cowl-type intake but I don't want to have to worry about rain water getting into it.  Any ideas for creative underhood plumbing?
Thanks,
Adam
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 383 Guests (See full list)
