Shiloh Ridge
95whtZR2
Well, I posted the same thing in the forum for Texas, but noone ever looks in there so here it is...
Some of my friends and I are going to Shiloh Ridge for memorial day, we are coming on Friday the 23rd of May, there is going to be guys with 4x4 pickups, atv's, dirt bikes, and an RV(not sure what kind, if t is a traior or an actual RV) But if anyone is interested just post a reply on here, or PM me. They are 95% sure this one isn't gonna be canceled... Look forward t seeing some people there...
Tom
There are a couple of us that watch the Texas forum, I being one of them.  Just didn't respond till I did some research.
Tentatively (haven't spoken with the wife yet), I plan on being there.  A friend of mine with a lifted Dodge plans on coming as well.  He has been before and ever since he has been wanting me to go.  Every trip he has planned with pavementsucks.com has been cancelled.  But this weekend sounds good.  Keep me posted.
Let's get some more people from Texas enthused about it and get them to come out too.  It would be a great place to meet and talk about trucks!
B.J.
Cool, I am pretty sure that there will be about 8 trucks (myself included) coming form Austin... If anyone is on the way or near Austin and wants to follow us up there let me know and  can arrange something. I will keep everyone posted about it. I wasn't sure wether or not anyone was reading the post or not, but I figured I might as well post it here as well, seeing as how it is a little more than a month away!!! I am excited, I have never taken my vehicle out there, but I know about how well it will do. If anyone doesn't know the Shiloh Ridge Website it is there. I will regularly update you all.
Tom
  • 4 weeks later...
You know this is a bunch of :D Everytime I plan something it never pans out :wtf:  :crackup: so by now ya'll know what I mean... the trip is off for my friends because graduation is that weekend, and on top of that I couldn't start today like planned so I owuldn't have the money to go anyway :wtf: I am sorry for the inconvenience, but I am going this summer and I am sure they are going to want to go as well, so I will let ya'll know in advance about any plans... this looked like it was really gonna happen too :smash:
Tom
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 700 Guests (See full list)
