Can you really fit 35's with a 4 inch lift with no problems?!&
I just spoke with my local suspension lift shop and they said it is impossible to fit 35's with only a 4 inch lift.... 6inch lift minimum to do so.
I've seen a few members on this site with the 4 inch lift saying they have no rubbing at all with 35's.
Was hoping you guys can shed some light... I'm looking to put a lift on soon.
Thanks!!!
Is it possible: Yes
Would I suggest doing it: No
There is nothing worse than ordering 3k in tires and 3k in lift parts, only to find out that your set up
Won't fit
The best thing you can do is find 3 trucks with the exact same set up you want before ordering any set up. Especially offset and backspace on wheels
Worked at a Customs shop, and seen a lot of people get really pissed lol
Is yours a 4wd? I'm installing 3.5 lift spindles from CST and they will clear 35s, but it only works on 2wd of course
Enviado desde mi LG-D855 mediante Tapatalk
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 886 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
