Well I'll be a Monkey's Uncle!
General Lee 01
The X-Terra is in the shop for a day (A\C problems).
Right now there is a '03 Dodge Dakota (Rental) in the driveway.
To tell yall the truth, I kinda like it.  :crazy:
It has the 4.7L V8, which has me impressed (Keep in mind, I'm used to 4 Cylinders :banghead: )
Any thoughts?
To tell yall the truth, I kinda like it.  :banghead:
It has the 4.7L V8, which has me impressed (Keep in mind, I'm used to 4 Cylinders :cool: )
Any thoughts?
I had one of those as a rental last year. The one I was using had a Magnum V8, I believe a sport model. Man that little thing would run. I'm very ashamed to say this but, it would defiantly eat any of my trucks. :crazy:
My buddy has one...quad cab with the 4.7.  When we aint haulin quads, its an even match...he cant pull away...after he swore he could.  LOL.  When we haul ATV's....its over and he's looking at my tailgate...
All in all, they are not bad trucks...one thing I dont like is the tranny...#### thing feels like its slipping for each gear....normal for this tranny....
All in all, I was not impressed with the interior or the ride. The interior seemed cheep and kind of plain. The one I rented had the 5.9 mag. V8 in it. The power level was VERY impressive.
I wouldn't put a stock 1500 up against a Dakota Sport R/T. :banghead:
:crazy:  All The Way!
If your Nissan dealer is like mine that repair will be $1000 for parts and $800 for labor.   :crazy:
Ummmm....or it will be covered under warranty
It wasn't covered by the warranty.
The belts had to be tightened (Don't know if they worked their way loose or what), while they had it, they changed out the differential fluid (WITH my mom's permission). And someother odds and ends.
It all came out to around $250
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 402 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
