Cam swap in LH6?
Has anyone ever swapped/upgraded a 5.3 LH6 VIN "M" cam? I want to upgrade the cam as I think the stock one is causing a misfire in cylinder 8. Truck has AFM but its not on the AFM cylinders. I have swapped fuel injectors, coil packs, replaced spark plugs/wires and still a miss. Can only think either the valve isn't seating properly or the lobes are worn. I have taken off the valve cover and there isn't anything obvious such as a broken spring or bent rod.
I also want to do the swap to gain more torque and power however I don't want to get something too aggressive. I don't care about fuel mileage and I don't mind replacing lifters, spirngs, push rods, and rockers as I do it.
Is there anyone out there who has done this swap or can recommend a cam? I have tried emailing Comp Cams but haven't heard from them. I will trying calling to see if a tech can point me in the right direction.
Thanks
Contacted Comp Cams today, they had two options. One with a DOD delete and one without.
With DOD: P/N 656-421-13
216/228 @ 50
Lift 500 114 Lobe
Without DOD: P/N 156-401-13 (Summit is saying this part is for a 6.0L)
214/228
Lift 559/571 114 Lobe
Started looking up DOD Delete Kits and Texas Speed has one with everything needed for about $400 except cam of course.
But I did find a cam on there for $434 with springs.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 399 Guests (See full list)
