Hvac only have hot air on defrost. 2000 blazer
Heater works but only when on defrost. It is the auto a/c controller and I installed new ac Delco but same trouble. Every other function works. Any info would be great.
I have a 2000 Jimmy (112,000km!) and I had a vacuum leak that affected the HVAC dampers and 2wd-4wd electronic shift (the actuator is under the battery). Fixed the leak also fixed the hvac issues.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
