Ride quality
greyghost03
I have recently started riding w/a friend to work - me 1 wk, him 1 wk. He just bought a 2003 F150 ex cab just before we started riding together. This week was the first week I rode w/ him and I must say my Silverado rides much better than his F150. I don't know if the suspension is that much tighter (stiffer) on his F150 but I could feel every little bump we hit!
Something else I noticed was a lot more cabin (road) noise at highway speeds.
No flame intended towards Ford, I'm just stating my observations from riding in his truck.
BTW- our ride to work is 30 miles one way so it's not like we just drive down a few bumpy roads to get to work!
Just FYI :cheers:
I'm not a big Ford fan ether. I know I would never buy one, that's for sure.
I used to have to drive Ford trucks and vans for work, and one thing I remember really hating, was the shift points on heavy acceleration. I remember when trying to pass someone and the passing gear would kick in, it sounded as if the engine was going to blow! And the tranny never shifted smooth coming out of the lower gear in that situation either. It kinda hung in gear a few extra seconds, even when you let off the gas.
IMO the truck never felt as solid as a GM either.
I understand the new '04 F150 should ride much better than the current truck (which BTW will still be sold in '04 also as an F150 "Classic" edition or something like that)
Yeah, it will be called the Hertiage edition. Chevys have the best ride out of all pickups.
OK here goes ford cheap Chevy not cheap
cant make it more simple than that
gm rocks
gm rocks
You get what you pay for. Chevys may cost a little more to buy, but they save you money down the road.
Dodge's quality in the new pickups has improved immensely though I must say. At my work we pull trailers (20,20,24) with 2500's. the 00 sucks, ride, morning its a b!tch to start 360 has no umph with a loaded enclosed trailer. 02 same model is night and day. the 03 (old body style) is simply no comparison to the other two.
None ride as well as any chevy. Thats a given, chevy's are 8-12 thou more for less truck (options not quality)
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 437 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
