Left rear signal and brake light issue
I have a 2007 Silverado 1500 LT. When I turn the left blinker on the dash indicator flashes normally 3 times and then starts blinking fast. The front turn signal is working fine, but the rear lights don't blink at all. When I press the brakes, the left rear doesn't light either, nor the hazards. When I connect a trailer, the left signal works fine on it. The bulbs and fuses are all good but I am not getting any power to the lamp sockets. I replaced the junction block behind the rear bumper on the left side, but that did not fix anything. I am running out of ideas (and patience). Does anyone have any suggestions?? Thanks in advance!
I guess you saw my post yesterday? I'm having a signal issue also. Its not the same as yours but I did some research on youtube and found most of these problems where solved by replacing the signal flasher behind the dash.
Thanks Lynn! I even bought a Flasher #10383320 but cannot find the original to replace it.
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 324 Guests (See full list)
