So how do I tell which rearend I have
I have a 14 bolt rear end in my 2000 crewcab short bed. I have heard the term partial and full floater thrown around when talking about these rears also is there two different sizes available?. So what does this all mean
Also as i just got this truck and have never had a 2500 model, when I go to give it gas it feels like the rear end is locking into gear (as if it goes from free spool to locked in) as the truck starts moving. Is this a normal thing, could it be a neeed some new U-joints (I grabbed the driveshaft and it feels solid)?
thanks again for your knowledge...
Boones
Wingnut, I went thru the 54 options and figured out the following
GT4 - 373:1 ratio
G80 - Locking rear axle
So what does this tell me. (I thought there would be a code stating its a 14 bolt rear end versus a 10 bolt?
These codes one thru me for a loop
code X-88 - Chevrolet Conversion? could that be because of the
crewcab shortbed (its a rare option only in 99 and 00)
YD3 - Front Axle for scheduling GVW plate (this is a 2 wd)
I found a few other codes I could not translate
CMD - ?
R6P - ?
SLM - ?
VX5 - ?
ZQ3 - ?
1SB - ?
1SZ - ?
6XJ - ?
7XJ - ? (probably has something to do with the 6XJ code??
at the bottom of the list is BC/CC and U334D
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
