2014 lower control arm replacement with aluminum knuckle
I need to replace the lower ball joints on my 2014 Silverado Crew Cab 4wd. I did not want to deal with pressing out/in replacements, so I was looking to just replace the entire lower arm. I wanted moog, but to the best of my searching they do not make a replacement if you have the aluminum knuckle. Does anyone have any suggestions for replacements? I searched rockauto, but was not exactly sure what would work, as some do not mention the aluminum knuckle.
Thanks in advance for your help!
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
