6.0 \ 4l80e swap tuning issues
I have a 1999 Silverado ( the 99-02 style) I recently replaced the original 4.8 and 4l60 with a cammed 6.0 lq4 and 4l80e transmission. This is a half ton single cab short wheel base 2 wd truck.
 2004 model lq4 engine,
new oil pump, beehive springs,
BTR stage 2 n\a truck cam
Stock 3\4 ton converter
2005 model 4l80e fresh rebuild
Cold air intake, shorty headers,
 having issues with what I believe is the tune.  Engine runs fine and strong transmission works mostly as it should. I'm not the tuner but I feel like I'm about to be.
Issue is as follows.
70 mph flat highway cruising in manual 3rd gear
Scan tool pids
Engine rpm - 2800
Input shaft speed- 2800 rpm
Turbine speed - 2800 rpm
Tcc slip - 0 rpm
TC locked
Same highway cruising in "D"
Trans in 4 the gear
Pids
Engine rpm - 2100
Input shaft speed- 1950 rpm
Turbine speed -1950 rpm
Tcc slip - 150
TC locked
If I give it throttle and cause it to downshift into 3rd tcc slip goes to 0 once it goes into third
If I use the scan tool to command the tcc to lock or unlock, it does and rpms jump and go back down as they should which means it's working. By my logic achieving lockup in 3rd means that the TC, tcc valve and bore, tc solenoid, fluid level and pressure, end electronics are indeed good.  So with those being good and working correctly in 3rd they should work in 4th as well.
I'm having trouble deciphering if the slip rpm I'm seeing is a glitch or other issue in the PCM logic or if the tune is simply not right like the setup or segment swap either being bad, corrupted or mismatched os, or even a lack of segment swap.
I don't have a tune file to upload sadly but I'm at my wit's end with this. I can handle all electrical and mechanical repairs and testing and have done as much as I can find to do but the computer part might as well be an alien language to me.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
