2020 AT4 6.2L 10 speed problem
OK. I have a 20 AT4 6.2L 10 speed Crew cab. A couple weeks ago I received the brake reprogram recall notice from GM so I made an appointment to have this done yesterday. Let me say first that bought this 30 Jan 20 and I have had zero problems with my brakes or the driveability of this truck. The engine and transmission have been flawless till now. Extremely powerful and smooth shifting.
I was a bit apprehensive about getting the brake module reprogrammed but I decided to get it done because of the safety aspect. I don't want my brakes to fail like I have read the horror stories from some people on these group chats.
Well they did the reprogram yesterday. It took them about an hour and then they sent me on my way. I drove about 2 or 3 miles from the dealership and was traveling about 50mph when there was a big jerk and bang/slam in the driveline. At that moment the engine light came on and the transmission was acting like it was in neutral. I pressed the accelerator and the engine just twisted up to about 4000 rpms like it wasn't in gear so I took my foot off the pedal and with my foot off the pedal the engine revved up over 6000 rpms for about 5 seconds then went back down to idle. I then pulled over and turned off the truck. I called the dealer and told them that I was having problems and I was on my way back if possible. I restarted the truck, put it in reverse and turned around. The truck would move but the engine had to do about 4000 rpms to get moving in reverse or forward. I limped it back to the dealer. After I explained to the service writer what happened, she said "well what we did to the truck has nothing to do with my problem." I told her that I have had zero problems until they performed the recall so it obviously IS related! They took it in the shop and have no idea what is wrong so now they have put their "transmission specialist" on it. Needless to say, he can't figure it out either so they put me in a rental for now.
I am waiting to hear from them today.
Has anyone on here got any insight on this or heard of this problem after a brake module reprogram? I would think the brake system has nothing to do with driveability but it seemingly does.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 402 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
