Yukon Denail Axle Ratio
Have a 2002 Yukon Denali AWD. How can I find out the rear
axle ratio of it? I thought I could look inside the driver's door, but
not sure what to check.
Reason I ask is because I bought a new boat that will have a towing weight
of 5,000lbs. Correct me if I am worng, but it does have a max tow rating of
8,200lbs. with a weight dist. hitch. The Denali does have a factory
installed hitch.
Great forum. Thanks in advance for the help.
Todd
if your Denali has the 6.0 litere engine then you most likely have the 4:10 axle
if it is 5.3 then most likely has 3:72
Thanks for the reply. I figured it was the 3.73, but just wanted another opinion. BTW, I towed the boat the other day and it does a great job, especailly with the auto leveling.
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 428 Guests (See full list)
