Installing GM 3300 Factory Alarm
firecadet613
Hey UPS is bringing me my new GM 3300 alarm, comparable to the 3400 some members have used here but this one will work on my Blazer. Any tips or tricks or advice for the install, I'll be doing it myself and want it to go as smoothly as possible.
Joe
I installed a GM-3400 alarm on my Tahoe. Really, if you have any kind of experience with working on your vehicle, you shouldn't have any problems at all. Just find somewhere under the hood to mount the siren, locate a place for the toggle switch and then mount the alarm module and shock sensor somewhere under the dash. My only recommendation would be to mount the shock sensor on some large wiring bundle instead of on a rigid support bracket. I mounted mine on a support bracket at first and the alarm would go off with every loud exhausted car and with every thunderclap. I moved it and secured it to a bundle of wires and haven't had that problem since but just bumping the car will make the warning chirps.
Again, it is a very straightforward install and you shouldn't have any problems.
B.J.
Hey thanks BJ, whats the toggle switch for? Where did you mount the siren under the hood and do I just pick a wiring harness/bundle under my dash to mount the shock sensor on?
Joe
I guess it isn't really a toggle switch but a push button type thing to put the alarm in "valet" mode. Yes, I just chose a large bundle of wires to mount the shock sensor to. And for the siren, I have a Tahoe, but on the passenger side under the hood spring there is a large opening. I mounted the siren over there against the firewall.
Good luck,
B.J.
Got it all hooked up and it doesn't work. Had my brother who's an electrical engineer help with the install, says the control modual must be dead. He's sending me another to try it out, keeping my fingers crossed.
Joe
Joe
Lets hope it works ok when that new part comes in :rolleyes:
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,301 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
