I have search for a couple hours and am somewhat computer illiterate but i have been looking for measurements to install the factory roof lights on my 2020 Silverado 2500hd i have found some measurements for earlier trucks but nothing on the new body. would anyone know or have the measurements of the factory installed roof lights?
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,480 Guests (See full list)
    • I have 2 choices.
