Hello,
I just purchased a 2021 Denali 3500 HD Crew Cab 1 ton truck in January.  In February 2021, I encountered a issue of  not being able to shift out of D (drive) due to snow/slush buildup where the skid plate protects the transmission gear shifter under the driver seat.  The GMC dealer in Grangeville, Idaho looked at the shifter area and said to take the rig to the car wash to use the water sprayer to melt out the packed snow from around the shifter.  Luckily I had a diesel guy with me on my travels to Boise, so he was able to spray the water up inside the skid plate area to melt the snow from the gear shifter, and then I was able to shift the transmission out of drive into the other gears (N, R, P).  I was completely surprised as well as my associate when I pulled up into my storage unit in Grangeville that I could not shift out of drive to park the truck or reverse out of storage unit. I couldn’t take my foot off the brake and and it put me in a extremely dangerous situation.
I want to be clear that my driving up to Elk City occurred on State highways 95, 14 and on county roads that are plowed on a daily basis when snow storms frequent our state.  The temperature in Grangeville that day was mid 40's. There was no other snow buildup under the truck.  I was not off-roading in areas that were not plowed.  My friend also owns a 2020 Denali 1ton up in elk city who bought their truck from Dennis Dillon.  They have gotten their truck buried in snow that they had to get a piece of equipment to pull it out- and did not have any snow packed up in their skid plate area.  My friend has not encounter this issue with their truck that I have experienced.
Has anyone also experienced similar issue where they could not shift their truck out of D gear?  I am new to this forum and couldn't find any information related to the issue I experienced. If it is in a thread somewhere, can you point me in the right direction?
Thank you,
Karen
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 640 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
