I have a RWD 2011 Silverado RCSB that is standard height.
I want to lower it using the McGaughys 3/5 - 4/6 Deluxe Drop Kit W/ Shocks Part #34070.
If I put 20s on it what would be the ideal size tire to not push the envelope of it rubbing?
What about 22s, would that even be an option? If so same question, what is the best size tire on 22" wheels that wouldn't rub?
Also if anyone has pics of this drop on a similar vehicle I would love to see them.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,360 Guests (See full list)
    • I have 2 choices.
