2016 Silverado 2500 HD. IO5  I installed a hmi 2.5 to my truck. It added CarPlay. Very happy with the hmi.
when going into reverse the screen goes blue/black says service rear view camera.
I can also go to setting and have option to add grids.
so I assume I could add a rear view backup camera to the existing female plug u def behind the bumper 8 pin.
can someone tell me what and where to get a male harness to plug into the female connector under/ behind the
bumper. I’ll assume my hmi is ready and programmed for a rear view backup camera.
I ordered a harness from bob’s mirrors but it a female pigtail. So I need a male pigtail. Which I can order from them.
I assume.
Resolved. Thanks to this forum. Hmi 2.5 gray connector to
X63a connectors at rear bumper. Use connector x900 tailgate harness to chassis harness x63a.
pins 26 and 27 for video.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,313 Guests (See full list)
