I’m looking to level the front of my trail boss, the shop doing the work is recommending the rough country 1.5 kit
This is the link
https://www.roughcountry.com/gmc-leveling-lift-kit-1319.html?find=2020-chevy-silverado-1500-4wd-740495
is there anything I should know going this route? Will my angles be ok, I’m keeping the stock 18s but looking at going with
285/70/18 or 285/75/18 ridge grapplers. I’ve looked all over this forum but can’t find the exact answer to my question. Any input would be appreciated
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,399 Guests (See full list)
    • I have 2 choices.
