I have just had my microphone replaced at the dealer, and it does not pick it up at all. The dealer “confirmed” it worked, but it isn’t picking it up at all. Does any have a clue what’s wrong with it?
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
