Repairing my motorhome
Worktruck
I will be attempting to repair the roof and ceiling of my motorhome in the next couple of weeks. A tree fell on it in a wind storm last fall. Anyone ever done something like this? Maybe give me some pointers? I mean other than "Take it to a professional!". :P
Good luck!! Sometimes roof and side repairs can go good and othertimes you can open a real can of worms. You can usually save the skin if it isn't ripped or cut but depending on what style of rig you have the roof trusses can be kinked and not easily straightened. You might call a dealer to see where in your area you might be able to locate a shop that repairs motorhomes they may have rigs that are damaged but have good trusses and box rails. Also if your unit isn't real old check with the manufacturer about warranty skins and rails etc. They sometimes have a stock that were pulled out of a unit for one reason or another. Just take your time and check all of the damaged area real well and you shouldn't have much problem. The hardest part is to reseal everything so it doesn't leak. So often there is hidden damage in the roof areas so pay special attention to that
Thanks apache for the input. The only roof or side rail that is bent is at the rear right corner where the roof and side meet. The corner at the top of the side wall. It is bent down a couple of inches. I will try to straighten it and if I cant I'll cut it out and weld in a new piece. The ceiling panels are problably going to be the hard part. The factory roof was applied to the roof rails before it was attached to the walls, so the panels are sandwiched between the roof and top wall rails. I guess I'll have to apply the new ceiling over the old. :P
On some units you can pull the batten strips that hold the ceiling panels in place and pull the panels loose. Depending on how long they have been there, sometimes they come out with a little tug. Other times you have to cut along the wall tops and replace the ceiling panels then install corner stripping to hold the panels in place and cover the cut. About the only alternative is to strip the wall area around the damage but that gets labor intensive and frustrating.
Great input apache. The wall panels are glued to the styrofoam in the wall cavity so I don't think I can remove the panels without damaging the insulation. I guess I'll have to cut the ceiling panels at the top of the wall and remove. I've been to Home Cheapo to look at the available FRP panels and trim, just cant find a trim to finish the wall/ceiling joint the way I want. Also I'd like to remove the bathroom partition so I don't have a joint in the ceiling there but cant figure out how the partition is secured. Bet it's bolted thru the roof frame huh? Thanks again for the input.
On a lot of units like you said the panels are made as a sub assembly then installed so taking them apart involves reverse removal which is time consuming and difficult Thats why its so expensive to have it done professionally. So the ceiling is probably bolted together through the roof. Trying to work on motorhomes taxes your patience cause its not like anything else that you usually do. The parts are different and are one of a kind so you have to improvise. But just take your time and good luck.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,138 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
