Keyless Entry on 1997 Tahoe
My 1997 Tahoe has a GM aftermarket keyless entry system. Does anyone know how I can find a remote for this since none came with the vehicle when I bought it?
Also, how do I program the new remote?
Thank you for your time.
Instructions for old body style trucks
The OBDII Data Link Connector (DLC) is located under the dashboard near the steering wheel shaft. The image below is rotated 90 degrees to the left (left is 'up'). Use a paper clip bent into a 'U' to ground the pins as instructed.
1.Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds. KEEP THIS CONNECTION WHILE YOU DO THE FOLLOWING
2.Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
3.Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
4.Remove the ground applied to the DLC.
5.Lock and unlock the doors in order to verify the transmitter operation.
6.Activate the rear window release in order to verify the transmitter operation.
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
