The 4WD isn't working right on my 84' S10 Blazer.
I shift it into 4Hi or 4Lo and only the rear wheels pull or something.  I got stuck in some soft dry dirt the other day.
So I figure I have some trouble w/ the transfer case or front diff.  Haven't serviced either since I've owned it (bout 7 years).
Any ideas?  I don't hear any crunching or grinding.
P.S.  It used to work when I got the truck, we used to climb some pretty nice hills.
Does the 4wd light come on?
Check the thermal relay on the front axle. If you get 12vdc on the wire, the relay is most likely the problem. These are a fairly high-fail item in the newer trucks, Easy to change and I think they cost around $50-$100.
  • 4 weeks later...
Yes, it is a vaccuum actuator. Looks like a little ball valve with vaccuum lines coming off of it, it is screwed in on top of the transfer case. These notoriously fail. We even keep an extra one in our 91 Blazer in case it fails during a snowstorm. It is the vaccuum that engages your hubs, that is why when you pull the lever you don't get four wheel drive immidiately like you do with the push buttom. The vaccuum has to build to engage the hubs.
I am pretty sure it is on the top, driver side of the transfer case.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 796 Guests (See full list)
