Just saw this on the dealer lot
I was just down the dealer lot to get some Auto Trac - blue transfere case lube and there was a 2500 HD with a 4" RCD lift on it. The truck was brand new still with the dealer tag in the window on the lot. I didn't see the bottom line price with the lift. So I guess this is one that they will warranty with the lift? I imagine this is not something done through GM? The tires on it looked stock and so did the wheels.
I remember one time the Toyota dealer did some different options to the 4 runners when they were trying to push them out which included them with different than stock wheels. Something that the dealer did at time of getting them from the docks I was told.
The dealers out here do some different things to push these trucks. The same dealer was also selling Tahoes with the Chevy Thunder Package which included a different exhaust and the super charger. I don't think that package is offered any more but I may be wrong. I thought i heard that GM told them to stop selling them that way. So I wonder if this is thee next Gimmic to sell trucks with lifts included.
There are some used lots out here that you can get trucks already done up with lifts and larger tires.
Around the DFW area, a lot of the dealers will have a truck or two on the lot that they have tricked out. Lifts, dual exhaust, custom paint, wheels, tires etc... All of them that I have looked at had the original factory warranty.
HtHs,
James.
I had my supercharger installed by my dealers aftermarket facility...full warranty on everything since they had it done. If the dealer sells it new with all of the things they do to it then they'll honor the warranty - unless you were told otherwise. I don't know if another competing dealer would honor the warrantty but the dealer you bought it from will.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
