How many people in your town...
The SPEEDY
...have those stupid arse stick on hood scoops? I have seen them on just about every make and modle of car around here. Sadly i see most of them on trucks :thumbs:
They are EVERYWHERE. It is retarded and funny at the same time. I dont understand why those people think they look good. Especially when they are unpainted! That and Im pretty sure they know they arent functional. Why they put them on their beaters I do not know.
Funny you should mention that....i went to the autoparts store the other day, and this dood had one on his volvo. It was really funny, his volvo was red, and you could tell the scoop was the white/cream color that it came from the factory in.....BTW this wasn't a new volvo, it was the boxy safe volvo from 1990
You couldn't GIVE me anything from LUND. Although, I'm ashamed to say it, my hood guard is from them, but it required no painting and bolted right on. But these other tools, that get that catelog and buy one of everything, makes the truck look really plastic and stupid!
A little off the subject, but, i have heard of i guy who had a 'maro SS and he had his NOS purge blast out of the hood scoop. Pretty cool, but it would be awsome if he could purge then rev his engine and suck the purge back in!!!!!
Wow, that's tacky! Not too many around here. Socal 100K + city.
What drives me nuts are those nasty spinning hubcaps...more and more everyday. I just couldn't put those on my car/truck and think I was pimp! :)
I have to agree with you there. Those spinners are kinda of silly but the mexicans that work the nurseries here like them. (those things are not cheap either)
I've seen a few around here, evenm a few that were not painted, just stuck on, too funny.
Here is my question though, what would you consider a "Home Town" to be. Where you live, where you were born, what? :)
Back in the late 60's and early 70's, reverse scoops or cowl induction was a big deal.
Yep, cowl induction was a big thing. I don't think it's gone out of style much, but that's just me. As far as the fake hood scoops, I don't think they look too bad as long as they're painted the same color as the vehicle. But it is a shame that they aren't functional. My brother's (96z71asskicker) '96 Silverado has the scoops. Looks cool IMO.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,301 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
