88-95 V6 vs. V8
I'm looking for a 88-95 4x4, 5 speed, short wheelbase, 350.  I can't find one.  A buddy told me the V6 trucks used all the same parts, except the motor.  Do the V6 trucks have the V8 radiator, tranny, diffs, transfer, brakes, suspension, etc?
Are there any good 88-95 info/tech resources on the web?  Thanks for the help.
The tranny, differentials, transfer case, brakes, supsension are all the same as far as I know.  I believe the V8's use a bigger radiator though.
Not sure where you are from, but try this site to look for your truck.
http://www1.getauto.com/
You can search by dealer or vehicle in your area or other states.
As far as the V-8 vs. the V-6: the V-6 changed over to the Vortec motor in late 93 - early 94 I believe. HP was rated 190 - 200 HP for the Vortecs. Not sure what the rating was before the Vortec. The V-8s in those years (from what I've been told) are 200 HP - 300 ft. lbs torque. The V-8 changed over to the Vortec in 96 - more HP.
I believe that the 5spd tranny was the same on both, but don't quote me on that.
Hope this helps.
bassdog
Thanks for the help.  I'm thinking a junkyard turbo setup on the 4.3 might tide me over until I can put together a twin turbo 350.
Quote from bassdog, posted on Nov. 16 2001,09:23
bassdog
Vortecs, both V-6's & V-8's, weren't available in trucks until 1996.
Well, both of you are right in a way.  My Dads 94 C1500 has the 4.3 V6 in it, and it says Vortec right on the valve covers.  While it has Vortec heads, it isn't the same as the later Vortec motors.  My dad's 94 still uses throttle body injection.  It was in 96 like mentioned above, that all the motors changed to sequential fuel injection, along with alot of other changes.  These are the Vortec motors most are familiar with.
  • 5 years later...
Got a link for the junkyard turbo setup? I've been thinkin the same thing for my 89 V6 but cant find anything.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 703 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
