Component Grounding
I've dismissed it several times, but i keep seeing grounding kits on ebay... do they work, and if so, why aren't the components grounded that well from the factory? 5+hp?
taken from an Ebay auction:
This Ground Wire Connects to Alternator/A/C Compressor/Starter of the Vehicle.Constant grounding means better overall performance Want to help prevent power loss and ensure top performance of your ignition and other components? Then you need this kit .Provides a constant ground to your engine and to all the high-output power sources that make it work. It features a central grounding point that branches off to the major components of your engine (transmission ground, block ground, alternator ground and ignition ground).
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33692
Friend of mine is a big stero/home theater buff. He was talking to me about that. Said it actually helps. Not much but it helped. I may give it a shot to see what it actually does. He said he would make me the cable.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 627 Guests (See full list)
