Rattle In Steering Column
Sorry If this has been discussed before, Im new to this GREAT site.
I have a '03 Silverado Z71 ext cab. When I am turning the truck at any speed, there is a bumping in the sterring column. It almost sounds as if something is tapping the plastic housing surrounding the column. I can feel it in the steering wheel but not in the floorboard. I cant really tell if it is tied to the suspension or not, but it is definately not tied to the motion of the steering wheel (ie: it does not tap when I turn the wheel sitting still). It does not affect the handling of the truck.
Any ideas?? Thanks.
The dreaded intermediate steering shaft klunk. Stop by the dealer and let them know your truck is affected. They will put you on the list for a new shaft. There is a national back order on the part and will probably take several weeks before it arrives.
Is this part needed, covered by GM, etc? My truck is out of warranty and the knock is really more aggravating than anything. I can certainly live with it if it is going to be a bundle to fix. Thanks!
there is another fix -- it is to remove the intermediate steering shaft and re-lube it. i did this myself (the re-lube kit was like $10) two years ago and it's been fine since.
Yeah I see that procedure above. It sounds like some people are having to redo the lube. I wouldnt mind having the shaft replaced if its not too costly, and certainly wouldnt mind it if it is a safety issue.
Same here, been about 2 years and so far so good. I've heard that the noise comes back with this fix, but so far I've been lucky. If it only costs me $10-$12 every 2 to 3 years, that's a maintenance item I can live with.
This shaft has been redesigned in the past, and the noise always seems to return. If, in a few years, the latest and greatest shafts are still holding up, then I'll probably invest in one.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 292 Guests (See full list)
