check this video out!
woodpecker
The first one: The football players get paid for and are equiped for it. I still think they see plenty of stars, but they also see plenty of $$$$$! For everyone else, I feel this applies: "Stupidity is a privilage not a right, however, you ARE abusing the privilage!"
The second one: One of the funniest things I have ever seen!!! :thumbs::D
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 893 Guests (See full list)
