Volt Gauge Questions
Guest Friz
My 93 Chevy z-71 5.7, auto. is having some electrical
gremlins. I put a new alternator on the truck a couple weeks ago cause I lost a rectifier on the old one.
Well I have the new one on and the volt gauge inside the truck was reading right around 14 volts until yesterday. Now it reads a couple marks up from the red lines for low voltage. I had a electrical test done on it today, and at this "low gauge reading" it's putting 13.5 volts to the battery. At idle the alternator is putting out 22 to 25 amps. Is this normal? Or do I have a short somewhere? Thanks for the help guys, I've only had this truck a month now so I don't know what is normal for this gauge or truck
Tyry having your battery tested at an auto parts store. If your battery is developing a shorted cell it will draw excessive current from the alternator and show a lower reading on your voltmeter.  In a 12v battery you have 6 cellls each producing about 2.2 volts with the engine off. You should measure about 13.2 volts at the battery  terminals with the engine off.
Thanks Danno, I will have the battery tested for a possible short. At the battery with the engine off I
have 12.3 volts so the voltage maybe too low, right?
Brian
12.3 vdc means that you have a dead cell.
A good battery should read a minimum of 14 vdc
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,253 Guests (See full list)
