Power Windows
Provided you protect everything with fuses and relays you can do it. OF course you will need the plugs that go with those regulators too.
I did my Sierra with a kit from JC Whitney. The only draw back is the door panels look like crap with the plug where the old hand regulator handle was. I mounted the switches in the arm rests. Have thought about getting door panels from a truck that had power windows and locks but haven't done that yet. Its an easy install, took about 2 hrs total. Good Luck
If you wanna do a factory install on 99-02 you need:
both window regulators
both door wiring harnesses
both window switches
both power door panels
dash harness from LS or better truck
BCM from a power truck
power lock latches (if you don't power locks already)
Easy fo sheezy to install, although you have to totally remove the dash.
Yep, I did the factory install and highly recommend it. Just took 2 afternoons on the weekend, one to swap the dash harness and another to do the doors. Only time I needed a helper was when I had my wife help me snake the dash harness underhood.
I did spend almost a year collecting all the necessary parts off Ebay, but it was worth it. It also made it easy to add other things like factory keyless entry, factory pwr/htd mirrors, and even a glovebox light.
  • 1 year later...
  • 2 months later...
I have a 2003 base model silverado single cab that came with only power locks. I have the power window tracks, motors, switches door panels, door wiring harnesses and power mirrors from a 2003 Avalanche. I also purchased a drivers side door panel switches (for two windows instead of four). I know i will have to reprogram my BCM to make this work. I recently found out i will need a new dash wiring harness. If i purchase the harness should this work? I was told they redesigned the electronics of the switch in the 2003 but i have not been able to verify this.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 586 Guests (See full list)
