'06 C6 to get paddle shifter
Chris97K1500
Not sure if this has been posted on this board or not, but Digitalcorvettes sent me an email about the '06 C6 to get a Triptronic paddle shifter as an option. Sounds pretty cool. Chris
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 1 Anonymous, 591 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
