Engine has Erratic Operation
siml8r5
Hey there! I'm hoping you can help. I have a 99 Silverado LS 1500 with a 5.3L V8. It has 72k miles and I'm having problems with the engine. In the morning, it starts right up if it's cold. If I get it to Normal Operating Temp and shut it off for a half hour or so, it's harder than hell to start and when it does, I get white smoke out of the tail pipe and a rough idle for 10-20 seconds. Also, when I come to a stop during driving, it runs rough. Like it's mis-firing. Any ideas? :thumbs:
If I had to guess, and I do, I'd say internally leaking fuel pressure regulator. But there's only about 3 or 4 dozen things that could cause what you're experiencing, so without more specific diagnostic information, that's the best I can do.
Hey there! I'm hoping you can help. I have a 99 Silverado LS 1500 with a 5.3L V8. It has 72k miles and I'm having problems with the engine. In the morning, it starts right up if it's cold. If I get it to Normal Operating Temp and shut it off for a half hour or so, it's harder than hell to start and when it does, I get white smoke out of the tail pipe and a rough idle for 10-20 seconds. Also, when I come to a stop during driving, it runs rough. Like it's mis-firing. Any ideas? :ughdance:
WHITE SMOKE AND ROUGH RUNNING IS AN INDICATION OF ANTI-FREEZE LEAKING INTO THE CYLINDERS, ARE YOU LOSING ANY COOLENT? PULL THE SPARK PLUGS AND CHECK WHICH ONE OR ONES THAT HAVE NO CARBON ON THEM IF IT IS TWO CENTER PLUGS YOU GOT A BLOWN HEAD GASKET. ALL THE PLUGS SHOULD HAVE ABOUT THE SAME COLOR, IF ANY ARE DIFFERENT THAT WILL BE THE CLUE...
    Whit.the.COB
    Whit.the.COB
  • Who's Online   0 Members, 0 Anonymous, 1,179 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
