help with part #'s for steering wheel clockspring
lurchman0
Newbie here looks like a great site I hope you can answer aquick question for me. I am in the process of converting my 04 3500 crewcab over to the steering wheel controls I have purchased the wheel and I need the clockspring whith the wiring harness. I have located a new one for a really good price but it is for the suburban,denalli,yukon etc and not the HD silverado line it is part #26101829. It is my understanding that I need part #26101828 does anyone know if the clockspring of the suburban etc. will work on the silverado and what is the difference? Thank you
Welcome aboard :cheers:
I can't tell you the differences between the two but you definetly need part #26101828.
(Part #26101829 would be for a half-ton crew-cab)
you have to get the right one (#26101828), the difference is because of the airbag. The HD line has a single stage airbag setup and the rest have the dual stage airbag.
I'm another newbie.
I just bought an 05 1500 Silverado Crew Cab 4wd short box and 5300.
I want to do the same thing and have purchased a brand new 05 wheel with controls that should be here by Friday.
I've spoke to my local dealer who is is more then willing to help me get the Guage Cluster flashed with the correct override codes so that I can use the DIC.
My new question is what is the clock spring???? Isn't it part of the airbag? I bought a new 05 wheel hoping that it would interchange the best with my original 05 wheel. It's even the same color! Guess I should have asked the dealer.
Also, does anyone know, is the removal for the 05 steering wheel the same as the 99-02 models (Pull the fuse for 15 minutes and release the 2 pins on the back of the steering wheel to release the airbag?) I've got a nice PDF file that explains it in detail and have been told the 05 is similar.
Thanks!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
