Door Lock plates
Mighty HD
Since the search function is non-functional this morning again :sigh: , Hopefully someone will know what I am talking about.
A few weeks back someone posted that they got broke into and got a reply with a link to a site that made small metal plates that went behind the door locks to prevent someone from breaking into their truck via the locks.
It looked like a small silver metal plate that bolted right to the back of the door handle from the inside. If anyone knows what I'm looking for --please shoot me the link.
Thanks
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 1 Anonymous, 591 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
