Possible Exhaust tick
90Gmc
I have a 90 gmc with a 5.7 under acceleration a noise can be heard that sounds like a exhaust leak. But my only other option on the exhaust is the gasket/flange connecting the y pipe to the manifold. Or could it possibly be a Plug missing because the noise is in sink with the motor.... :(
Sometimes, some carefully added ATF down the throttle body will reveal smoke at the point of the leak. ATF smokes like heck when burned. Don't just dump a large amount in and hydro-lock the engine!
What do you mean by, "my only other option..." Is there an option you've tried you're not telling us?
OK i pulled a plug that could be messed up what does a filed plug look like and could that be the tick if the plug is not firing....
What kind of plug are you talking about? A spark plug? I have no idea what a "filed plug" is.
You've lost me. Can you be a little more detailed on what you're talking about?
ok yes its a spark plug and i pretty sure a filed plug is one that is not firing correctly...
I think the confusion is happening because a filed plug isn't one that won't fire.............a FOWLED spark plug is a plug that wont fire. :driving:
Do you mean a FOULED plug? (not a FOWLED plug). A fouled plug is one that has the electrode(s) coated with oil or severly carboned up, causing a misfire.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,132 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
