Oil Change on ramp
So today I was changing the oil out of my Saturn, and noticed that more oil will come out if I took it off the jack stands. So it seems like if you raised the front of the car higher, there are some pockets where oil could stay and not drain out. Having the car on a level surface is the best route.
I noticed this because I started to change the oil on a slanted driveway. But when I filled it up, I would only use 3qts instead of 4qts. So I changed it on a level drive way, on stands so I can get under it, but then lowered the car, and saw more oil coming out. Maybe it's a Saturn thing... I just crawl under my truck, no need to lift it.
Just a thought! :cheers:
What kind of Saturn? I just recently changed the oil for the first time in my wife's new '05 Ion. I drove it up on ramp and drained the oil into a new, clean pan that had lines on the inside for every quart. When all the oil was out, the level was on the 5 quart mark.
5 quarts in a Saturn? That's a lot for a small car. Maybe it's a safety margin for all of the college girls that buy them and never check/change the oil in 10 years. :cheers:
I use ramps on my '04 silv and always need the full 6 qts to refill
My roommate does not use ramps on his '04 tahoe and he can only fit about 5-5.5 qts
so, whatever that's worth...
Well, I mean, ramps plus on a slanted driveway. The additional "lift" from the driveway may cause oil to get stuck in places it wouldn't without a ramp at all. When it was on a level driveway and on ramps, it would get most of the oil. And when I took it off the ramp, a little more oil came out.
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
