Mythbusters
Polak
Mythbusters, on The Discovery Channel, busted the "Tailgate Down" myth a few nights ago.
They took two identical F#*ds, with the same amount of fuel and payload, and ran them down the highway to empty. One had the tailgate up, and the other down. The tailgate down truck ran out of fuel first, quite a bit sooner than the tailgate up truck. Something about loosing a designed "aero push" like in racing.
Anyone else believe the myth prior to it being busted?
I know my grandpa would always put the gate down if we were getting on the highway or going a long distance. In turn, I did the same thing prior to getting a bed cover.
Think of all the fuel, wasted! :gmc:
Are you chittin me? I always thought leaving the gate down improved gas mileage. In fact I have seen adds for tailgate nets that let the air thru for better performance/ gas mileage. All I can say is it has to be that they used F**ds for the test! Heheheehe. The Mythbusters sometimes screw up you know
The increase in drag caused by the removal of the tailgate was unexpected and seems counterintuitive. We believe when the tailgate is in the upright position, there is a bubble of slowly circulating air in the truck bed that forms a virtual bed cover of air and keeps most of the airflow around the truck from hitting the bed bottom and the inside of the tailgate. Removing the tailgate does not allow this bubble to form, which allows the faster moving air to interact aburptly with the bed bottom. This is very non-aerodynamic and causes the increase in drag. After testing was completed, we researched this phenomenon and found that results of a similar study confirm our hypothesis.
Hooray for Adam and Jaime! :cheers:
I used to think that the tailgate down was better too, but somewhere, sometime ago i was informed differently! Glad to see there is documented study on the trivial things we deem important! :banghead:
Next you guys will tell me that self gratification doesnt make you blind!
Well if that were true, they'd never have invinted the internet! Now where are my glasses? :banghead::cheers::cheers:
On all the truck forums I've been on, general concensus was it's better to keep the tailgate up, not just for fuel economy, but also for bedside strength and tailgate integrity. Some people have quoted official studies in those threads.
The Mythbusters results just pretty much proved what was already common knowledge on the forums. It was nice to see someone actually confirm it though.
I laugh when I see people driving around with their tailgates down too, and people who spent money to buy those "airgates".
BTW, Kari is hot!
Still a few variables there. IIRC they used a crew cab truck with a 5ft. bed. What if it were a regular cab truck with a full 8ft. bed? Or anything in between for that matter? Also, many things could affect their "bubble", such as a toolbox, a spare tire, or anything else in the bed. Not arguing with their results, but there are too many different situations to rush a definite judgement. Just my 2cents. :banghead:
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 341 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
