Suggested Reading for engine newbie
I am looking for a dummies guide so I can learn a little more about the performance numbers I am getting from my truck. Questions like:
my timing advance is xx degrees, is this normal, or an issue?
what is the normal temp range for a 454 with a 160degree thermostat?
When I look at the numbers from the MAF, what is low, what is high?
When a engine is too cold, will it effect the timing as well as LTFT and others?
as you can see, I need a basic book, but one geared at least to the chevy engines, and hopefully to the fuel injected 7.4l so I can really look at the nubmers I am getting, and then know if I am seeing normal operations or things indicating a problem.
My background is in computers, with little to no engine knowledge. I really need to be brought up from the basics.
Thanks,
dan finn
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 627 Guests (See full list)
