Allision Problems
I have a 2001 2500HD 8.1L with the allision, It was working fine last week, drove it home and parked it and did not have any problems. This morning I warmed it up and got in it to go to work and it will not move. I put it in reverse and it is like its in netural, If I put in in D it makes a loud clunk and will move onlly slightly. I don't know if the transmission control mod. can cause this or not, or can a transmission go bad just setting still. Any one had or seen this problem?
Thanks for any help!
Just as a note I live in Alabama so it's not real cold and the truck has 89k miles.
Same exact thing happened to my 02' HD's Allison last week. I replaced the neutral safety switch and all is fine once again.
In addition to what you are experiencing, my gear indicator on the dash was acting up and my doors were not unlocking automatically when I shifted into park.
It was a 10 minute job and I got the safety switch for $97 from my friend's shop.
Good luck.
It's on the drivers side of the tranny. It's located on the gear selector shaft. You'll see where your shift cable goes to the shift arm, the safety switch is about 6" long and the shift shaft slips through it.
It might pay for you to take the truck to a shop in your area and see if they can pull the code for you. I can't remember but I think my code was u700 but please don't quote me on that. I do know that the code had to be reset before the truck shifted properly.
Same thing happened to me except mine
sit for about 5 weeks. I had it taken to the
dealer where it worked fine. The story I was told is the
Allison bleeds back trans fluid bad. I was told
that if I had put the truck in park and let it
run for a while it would have been ok. Same
problem as you, I don't know!! Mine has been
fine after that!!
Bud :thumbs:
jd4110,
My Ally did exactly the same thing. Thought it was the NSBU (neutral safety switch), so I ordered one from GMDieselTech.com. Got the switch overnighted, installed it and all was well, so I thought. I drove it for about 5 miles, parked it, came back out and the tranny was doing it all over again!
I was pretty close to a dealer, so I limped it over there, stuck in 2nd gear. Dealer diagnosed and determined that the TCM (trans computer) was bad. They happened to have one in stock and I needed my truck back. So, $1100 later, the truck was fixed and has been fine ever since. By the way, after I got home, I found the computer at GMPartsDirect.com for around $400 when the dealer got me for $700+. Oh well, had to have it done.
Good Luck!
I just had the same problem with my Allison. All kinds of crazy things were happening. The PRNDL was screwed up, I was getting big clunks when shifting between F and R. The truck wouldn't shift past 3rd on the road and I was getting various fault codes. There is a TSB out there about replacing the neutral safety switch with a new one that shields the area where the shaft passes through it. It seems that our trucks throw junk up on the switch when making left turns which eventually shorts it out. The shield is supposed to cure that. The biggest problem I had with changing mine was getting the larger of the two electrical connectors out of it. You would swear it had been super glued into the switch. I had to break the switch away from around the connector to get it out. After replacing the switch and clearing the codes, all was well again.
Thanks to everyone!
I talked to a GM guy yesterday and he said that there was a tech bulletin on the fluid draining down after setting for a while and to put it in Netural for a while then shift gears, so I thought I would try that when I got home, but when I cranked it last night it was already working fine, I drove it to work this morning and so far no problems. We'll see.
Thanks again
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 585 Guests (See full list)
