Automatic A/C Problem
Got a good one for you guys, even has my local stealer stumped :D
2005 Silverado SS
It has the automatic climate control in it, it is set (push auto for 5 sec) for both sides to be the same temp.
When it is in auto mode, and set at lets say 65 and cabp temp is higher than normal 85-90 the fan speed will only come up about 4 bars on the little graph, UNLESS you turn the temp down 1 degree, then the fan speeds the rest of the way back up, you can increas you temp back to your previous temp and everything works fine..
I know that it takes a little bit to get a/c working and get cooled down and for fan to speed up but i let it set for 15 min going down road other day, before i got tired of it and lowered temp one degree and everthing was fine after that.
Truck has about 10k on it now, a/c worked great when it was new.
Matt
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 434 Guests (See full list)
