borgeson shaft
the borgeson did not work for me. check this out:
Due to the tolerances allowed for OEM specification, the upper connection
may not be as tight as it should be to eliminate the "Clunk' completely.
Very rarely do we run into this issue of a proper install not eliminating
the problem. The only thing left to do is to shim the upper connection.
The shimming material should be of quality material or the problem will
re-surface down the road. Loosen the upper connection and with a feeler
gauge, properly fit the correct size between the two surfaces, this
determines what thickness of shim material is required to correct the
problem. Once the material has been selected, fitted and installed,
re-torque the connection bolt to the factory specifications. The problem
should now be eliminated.
i re-installed the original shaft,after the lub kit, works great, for awhile. borgeson does not always work. there is no way to get a feeler guage into the upper connection.
Thanks for the heads-up. I still want a Borgeson shaft, just to prove to myself that the GM shaft is junk.
Didn't you post this a little while back about the Borgeson shaft ???
http://www.gm-trucks.com/forums/index.php?...71entry363971
So did it or did it not work for you ??
worked great for 2 days, then the clunking started at any speed, any turning angle. i re-tightened all connections, way beyond oem torque specs,still clunking.
Woww...you wouldn't think that the machining specs would vary that much between vehicles but I guess they certainly can ! :chevy:
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 250 Guests (See full list)
