What should valves sound like?
PaulQ
I'm using a stethoscope to adjust my valves and was hoping someone on here could tell how they should sound.
Currently I have them adjusted to where there is no tapping and it sounds like a smooth humming, for lack of a better term.
Is this right?
Any advice would be appreciated.
Paul Q.
Is this right?
Paul Q.
Loosen until the valve starts to tick. Tighten til the ticking stops, then another 1/2 turn.
Zero lash is when the ticking stops. Normally, you want zero lash plus 1/2 turn. Some will go a full turn but I like a 1/2 turn.
//90GMCZ71
  • 3 weeks later...
Valve Lash Adjustment
Turn the valve rocker arm nuts clockwise until all of the valve lash is removed.
Turn the crankshaft clockwise until the alignment mark on the crankshaft balancer is aligned with the notch in the engine front cover tab.
Look at the number 1 cylinder valves as the crankshaft balancer alignment mark approaches the notch in the engine front cover tab. If a valve moves as the alignment mark moves into position, the engine is in the number 6 firing position. If this happens, turn the crankshaft clockwise 1 revolution in order to reach the number 1 cylinder firing position.
With the engine in the number 1 firing position, adjust the exhaust valves for cylinders number 1, 3, 4, and 8 and the intake valves for cylinders number 1, 2, 5, and 7.
Turn the valve rocker arm nut counter clockwise until the valve lash is felt in the valve pushrod.
Turn the valve rocker arm nut clockwise until all the valve lash is removed. Zero valve lash can be felt by moving the valve pushrod up and down between your thumb and forefinger until there is no more up and down movement of the valve push rod.
When all the valve lash is removed, then turn the valve rocker arm nut clockwise 1 additional turn (360 degrees).
Turn the crankshaft clockwise 1 revolution until the alignment mark on the crankshaft balancer is aligned with the notch in the engine front cover tab.
With the engine in the number 6 firing position, adjust the exhaust valves for cylinders number 2, 5, 6, and 7 and the intake valves for cylinders number 3, 4, 6, and 8.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 409 Guests (See full list)
