I don't have the Torza Top, but I do have a Lund Tri-Fold cover which is very similar in design to the Torza Top. The Lund comes completely assembled and can be completely installed in 2 minutes right out of the box. It is well made and has not let in any water in the bed. It can also be completely removed in about 2 minutes for hauling large items, or folded in sections for smaller items. I would certainly recommend the Lund to anyone interested in a tri-fold cover.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 585 Guests (See full list)
