Engine Compression Test
Hi everybody,
I want to do an engine compression test on my van with a 5.0L V8. It has a distributor ignition system and I just wanted to make sure I have the compression test procedure correct, please correct me if any of my steps are incorrect, thanks.
Compression Test:
1- Make Sure Battery is fully charged
2- Remove all spark Plugs and air cleaner
3- Completely open throttle (WOT)
4- Remove ignition coil wire where it plugs into the distributor and ground the end that plugs into the distributor
5- attach compression gauge to spark plug hole and crank engine (How long should I crank the engine?)
6- Record compression readings
How long should I crank the engine during each reading?
Thanks in advance for all the help!
Luke
That's about it Lee, except having the engine at operating temp is better. Having a strong battery charger hooked up helps. You should crank the engine until the guage reading stops climbing. An engine in good shape usually takes 3-4 compression strokes to max out. The trick is to set the guage up so you can see it while cranking each time.
Vernon
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 842 Guests (See full list)
