Centercap Interchangeability?
I'm looking at sets of the 18" wheels from the '07 Escalade on e-bay, but I'm not so sure that I like the big Caddy emblem on the centercap - would look out of place on my RCLB pickup, I think.
Are there other centercap options for this wheel?
Thanks for reading.
Read this bulletin on the interchangabilty on the wheels from the "New-for'07" SUV's to the '99-current pickups.
Although it pertains to the 20" and 22" wheels,The offset issue also applies to the standard 18" wheels...........
Subject: Info - 20 Inch and 22 Inch Accessory Wheels Available Through GM Accessories #06-03-10-001B - (05/01/2006)
Models: 2007 Cadillac Escalade, Escalade ESV, Escalade EXT (20" and 22")
2007 Chevrolet Avalanche, Suburban, Tahoe (20" Only)
2007 GMC Yukon, Yukon XL (20" Only)
2007 GMC Yukon Denali, Yukon Denali XL (20" and 22")
This bulletin is being revised to add information on 22" wheels available for Denali models. Please discard Corporate Bulletin Number 06-03-10-001A (Section 03 -- Suspension).
The purpose of this bulletin is to provide a reference guide for the technician to upgrade a vehicle from factory wheels and tires to 20" or 22" wheels and tires, which are available through GM Accessories. This guide will cover the required vehicle modifications, module reprogramming and warranty information.
Important: 20" and 22" accessories wheels released for 2007 model year full-size utilities are NOT compatible/interchangeable with pre-2007 model year full-size trucks and utilities and vice versa. GM accessories wheels are validated and released for specific vehicle applications. In this case, a difference in wheel offsets exists between the different model years. Warranty coverage and dealer indemnification will not be provided in situations relating to incorrect application usage.
Vehicle Modifications
Tires (20")
GM offers two tires, the Bridgestone Dueler H/L Alenza P275/55R20 or the Goodyear Eagle LS2 P275/55R20, to be used in conjunction with the 20" accessory wheels. The Bridgestone Dueler and Goodyear Eagle tires have a Tire Performance Criteria (TPC) spec of 1245MS (molded on the sidewall) which meets or exceeds all Federal Safety guidelines.
Tires (22")
GM offers one tire, the Bridgestone Dueler H/L Alenza P285/45R22, to be used in conjunction with the 22" accessory wheels. The Bridgestone Dueler tire has a Tire Performance Criteria (TPC) spec of 1261MS (molded on the sidewall) which meets or exceeds all Federal Safety guidelines.
Important: When mounting the tires, rubber lubricant, GM P/N 12345884 (in Canada, 5728223), must be used. Also, the vehicle should not be driven aggressively (hard acceleration or braking) for at least 6-8 hours after tire mounting to allow the lubricant to dry. Failure to do so may cause the tire to slip on the rim. This condition will affect wheel balance which could result in a vibration.
Tire Label
After installing the recommended tires, place the provided tire label on the vehicle. The tire label should be located on the door jamb, near the original tire label, and should not cover up the original tire label. Be sure that the surface is clean and dry. The surface temperature should not be less than 21°C (65°F). The label is provided as a guide for tire inflation pressures and information relevant to occupant/cargo capacities.
Tire Type/Pressure Selection
To provide a more accurate function of the Tire Pressure Monitoring System, it is necessary to update the Remote Control Door Lock Receiver (RCDLR) with the correct tire type and pressure information. Using the Tech 2®, follow the steps listed below to select the appropriate tire type/pressure:
Install the scan tool.
Turn ignition ON with engine OFF.
Enter "Diagnostics" and build vehicle according to model year, vehicle line, etc.
Select "Body."
Select "RCDLR Module."
Select F2: Module Setup.
Select F5: Tire Type/Pressure Selection.
Select P-Metric Standard.
Select the front and rear tire pressure as noted on the new vehicle driver door placard sticker for the accessory wheels/tires.
Verify that the selections made are correct and press the enter key. The scan tool will flash "Procedure in Progress", then display "Procedure Complete."
Press the "exit" key to escape.
Tire Pressure Monitor (TPM) System
Important: Tire pressure sensors for 2007 model year full-size utilities are not compatible/interchangeable with pre-2007 model year full-size trucks and utilities and vice versa.
To avoid system malfunctions, it is necessary to install tire pressure sensors in the accessory wheels. Replacement sensors GM P/N 19155710 can be obtained or sensors from the OE wheels can be transferred to the accessory wheels. After the wheels are installed on the vehicle, it is necessary to learn the new sensor identification codes/locations into the remote control door lock receiver (RCDLR).
TPM Sensor Relearn Procedure
Turn ON the ignition, with the engine OFF.
Apply the parking brake.
Important: If the learn mode cannot be enabled, ensure the TPM system is enabled in the RCDLR. Use the following steps to enable the TPM system.
Install the Tech 2® to the vehicle.
Select "Body."
Select "Module Setup."
Select "TPM Option Enable."
Press the exit key to escape.
Using the DIC, press the vehicle information button until the RELEARN TIRE POSITIONS message displays. If your vehicle does not have the DIC buttons, press the trip odometer reset stem located on the instrument panel cluster until the RELEARN TIRE POSITIONS message displays. If your vehicle has the DIC buttons, press the set/reset button. The horn will sound twice to indicate the TPMs receiver is ready, and the TIRE LEARNING ACTIVE message will display. If your vehicle does not have the DIC buttons, press and hold the trip odometer reset stem until the horn chirps twice and the TIRE LEARNING ACTIVE message is displayed.
Alternate method: Simultaneously press the keyless entry transmitters lock and unlock buttons until a horn chirp sounds or use the scan tool and select Special Functions/Sensor Learn Mode Enable/Enable soft key. A horn chirp will sound indication the mode has been enabled.
Starting with the left front tire, hold the antenna of the J-46079 against the tire sidewall close to the wheel rim at the valve stem location then press and release the activate button and wait for a horn chirp, or increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before the 8-10 second pressure increase/decrease time period has been reached, or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached.
After the horn chirp has sounded, proceed as in step 4 for the next 3 sensors in the following order:
• Right front
• Right rear
• Left rear
After the LR sensor has been learned, turn OFF the ignition to exit the learn mode.
After the learn mode has been exited, adjust all tire pressures to the recommended PSI.
Spare Tire Hoist (22" Wheels Only)
Important: The new spare tire hoist is necessary due to the added amount of stress that the 22" wheel/tire system causes to the factory installed tire hoist. The tire hoist is also needed even if you do not put a 22" spare under the vehicle.
Replace the spare tire hoist with GM P/N 19158309. This modification is required for the following vehicles when installing 22' wheels.
• 2007 Cadillac Escalade
• 2007 Cadillac Escalade ESV
• 2007 Cadillac Escalade EXT
• 2007 GMC Yukon Denali
• 2007 GMC Yukon Denali XL
The following procedure should be followed for this modification.
If the vehicle is equipped with a spare tire stowage lock cylinder, open the spare tire lock cover on the bumper and using the ignition key, remove the lock.
Rotate the hoist shaft counterclockwise in order to lower the spare tire to the ground. Continue to rotate the shaft until the spare tire can be pulled out from under the vehicle and removed. If the spare tire does not lower to the ground, the secondary latch is engaged causing the tire not to lower.
If the secondary latch is engaged and the cable end is visible, perform the following procedure:
3.1. Tighten the cable by rotating the hoist shaft clockwise until you hear two clicks or feel it skip twice. You cannot overtighten the cable.
3.2. Loosen the cable by rotating the hoist shaft counterclockwise 3 or 4 turns.
3.3. If the spare tire can be lowered, repeat steps 1 and 2 to see if the spare tire can be removed.
3.4. If the spare tire cannot be lowered, rotate the hoist shaft counterclockwise until approximately 152 mm (6 in) of cable is exposed.
3.5. Raise and support the vehicle.
3.6. Place a transmission jack, or equivalent, under the spare tire.
3.7. Position the center of the transmission jack under the secondary latch release button at the center of the spare tire. Arrange the arms of the transmission jack so they will support the tire after it has been released.
3.8. Raise the jack until the spare tire stops moving upward and is firmly held in place, releasing the secondary latch.
3.9. Lower the tire. If the spare tire is hanging by the cable, rotate the hoist shaft counterclockwise until the tire is low enough to remove.
If the secondary latch is engaged and the cable end is NOT visible, perform the following procedure:
4.1. Raise and support the vehicle.
4.2. Place a transmission jack, or equivalent, under the spare tire.
4.3. Position the center of the transmission jack under the secondary latch release button at the center of the spare tire. Arrange the arms of the transmission jack so they will support the tire after it has been released.
4.4. Raise the jack until the spare tire stops moving upward and is firmly held in place, releasing the secondary latch.
4.5. Lower the tire and remove it from the jack.
Raise and support the vehicle if it is not already raised.
Depress the tabs, remove the guide shaft from the hoist collar, and slide the shaft toward the bumper.
Remove the collar from the hoist.
Remove the bolt.
Remove the hoist from the bracket.
Remove the spare tire hoist shaft guide from the bumper.
Install the spare tire hoist shaft guide to the bumper.
Install the hoist to the crossmember.
Install the bolt.
Tighten
Tighten the bolt to 40 N·m (30 lb ft).
Install the collar to the hoist.
Install the shaft to the hoist.
Install the spare tire to the hoist.
Rotate the hoist shaft clockwise until the spare tire is in position and the hoist clicks two times or it skips twice. You cannot overtighten the cable.
Remove the safety stands.
Lower the vehicle.
Install the spare tire stowage lock cylinder.
Module Reprogramming
For proper vehicle operation and to ensure coverage under the provisions of the new vehicle warranty, the vehicle must be reprogrammed with the correct calibrations as soon as the accessory wheels are installed.
Important: Module reprogramming must be done using Pass-Thru method.
Engine Control Module (ECM)
It will be necessary to reprogram the ECM for speedometer accuracy. Contact Techline (1-800-XXX-XXXX English or 1-800-XXX-XXXX French) to obtain a VCI number. Use the Service Programming System (SPS) and follow these steps:
Connect Tech 2® to vehicle and to TIS terminal.
Power ON the Tech 2®.
Select the proper reprogramming method: "Pass-Thru" and "Reprogram ECU", then "Next."
Build the vehicle.
Verify VIN is correct, then "Next."
Select the proper controller to be programmed: "ECM Engine Control Module."
Select the proper programming mode: "VCI", then "Next."
Enter the VCI number obtained when calling TCSC, then "OK."
On the following Calibration Selection screen, the speedometer calibration has now been added to the calibration set and the box is checked. If a box is not checked, you will have to make the appropriate calibration selection. All boxes must have check marks before going to the next step. Select "Next."
Once the reprogramming is complete, depending on the vehicle build you may be required to perform a Crankshaft Position Variation Learn procedure. Refer to the Checking and Clearing DTCs After Reprogramming procedure listed below.
Electronic Suspension Control Module (ESCM)
This reprogram is only required for the following vehicles and only applies to 20" applications.
• Chevrolet Suburban 4WD
• GMC Yukon XL 4WD
• GMC Yukon Denali AWD
With the Tech 2® still connected, select the proper reprogramming method: "Pass-Thru" and "Reprogram ECU", then "Next.".
Build the vehicle.
Select the proper controller to be programmed: "ESCM Electronic Suspension Control Module."
Select the proper programming mode: "Normal" , then "Next."
On the following screen, select the proper calibration "Real Time Damping."
From the part numbers displayed, select the one containing the correct wheel size in its description, then "Next."
On the following screen, select "Done."
Electronic Brake Control Module (EBCM)
Important: 2007 GMC Yukon Denali and Denali XL upsizing from factory 20" to accessory 22" are excluded from EBCM reprogramming.
Build the vehicle.
Select the proper controller to be programmed: "EBCM Electronic Brake Control Module."
On the following screen, select the proper calibration "Electronic Brake."
From the part numbers displayed, select the one containing the correct wheel size in its description, "Next."
DTCs codes may be set as a result of the programming process. In most cases the codes can be cleared using the Tech 2® and following the procedure listed below.
If required, perform the CKP System Variation Learn Procedure (SI Document ID # 1657049).
Select "Vehicle Control Systems."
Select correct engine.
Select "Vehicle DTC Information."
Select "DTC Display." Scan tool will check all modules for any DTCs that are set.
Select "View all DTCs."
Select "Clear all DTCs."
Calibration Information Documentation
Make a copy of the "Accessory Wheel and Tire Information Form" included in this bulletin.
Provide all information required on the form.
Make a copy of the completed form for the customer to keep in the vehicle along with their Owner's Manual.
File the original completed form in the Dealership's Vehicle Service History folder.
Important: If original equipment tires/wheels are reinstalled, it will be necessary to reset the programming of the PCM to the original specifications.
Warranty Information
Wheels
All GM Accessories sold and permanently installed on a GM vehicle PRIOR to new vehicle delivery will be covered under the provisions of the New Vehicle Limited Warranty.
For the U.S., in the event GM Accessories are installed AFTER new vehicle delivery, or are replaced under the new vehicle warranty, they will be covered (parts and labor) for the balance of the vehicle warranty, but in no event less than 12 months/12,000 miles. This coverage is only effective for GM Accessories permanently installed by a GM dealer or a GM approved ADI (Accessory Distributor / Installer).
For Canada, in the event GM Accessories are installed AFTER new vehicle delivery, they will be covered (parts and labor) for the balance of the vehicle warranty, or up to 12 months/unlimited kilometers depending on month installed. For replacement after the new vehicle warranty expires, but within the 12 months/unlimited kilometers coverage, refer to claim type "B" guidelines.
GM Accessories sold over-the-counter, or those not requiring installation, will continue to receive the standard GM Dealer Parts Warranty of 12 months from the date of purchase (parts only).
Tires
Any approved tire installed on a GM Vehicle PRIOR to delivery will be covered under the provisions of the New Vehicle Limited Warranty. Tires are covered against defects in material and workmanship. Tires are warranted for defects "without" prorated charge for tread mileage. Subsequent replacements under this warranty will continue to be covered for the remainder of the New Vehicle Limited Warranty.
Any approved tire installed on a GM Vehicle PRIOR to delivery may continue to be warranted on a prorated basis by the tire manufacturer once the New Vehicle Limited Warranty expires.
Any approved tire installed AFTER delivery will be covered under the provisions of the tire manufacturer warranty.
USA dealers should refer to GM Warranty Administration Bulletin 00-03-10-003I and GM Parts Process / Policy Bulletin IB03-001 for more information.
Canadian dealers should refer to GM Warranty Administration Bulletin 01-03-10-003B.
GM Warranty Claims Processing
Only GM dealerships have the ability to file warranty claims for GM Parts and Accessories. Therefore, any warranty claims filed against such parts must be handled by the servicing GM dealership. This includes those parts purchased from a GM-approved ADI (Accessory Distributor / Installer).
ACCESSORY WHEEL AND TIRE INFORMATION FORM
You have just modified your vehicle by installing an "Accessory Package" which includes Wheels and Tires. This form contains important information about your accessory installation. In an effort to provide superior service to you, our customer, we ask that you please present this form to your Servicing Dealer when removing or installing wheels and tires on your vehicle. This form contains important information necessary to service your vehicle.
Important: Please store this form in the vehicle with your Owner's Manual. A record of this form will also be kept on file at your Servicing Dealer.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Dale - Thanks for all that man, I really appreciate it. Truck is out of warranty anyway, but the last thing I want to do is eat my ball joints or front hubs with too much offset :cool:.
Guess its back to the drawing board on this one!
    Selfman
    Selfman
  • Who's Online   1 Member, 0 Anonymous, 379 Guests (See full list)
