2002 Tahoe rear A/C
gfunk100
The rear A/C suddenly does not work. The front is operating very well. The heater portion works both in front and in the rear. any suggestions?
the rear might have a separate resivoir?
or the whole system might be low, the bias might just be to the front since it's so much closer to the compressor. that's just a guess. have it checked, or get one of those neat kits with a guage and check it out.
Document ID# 1337786
2003 Chevrolet TrailBlazer - 4WD
Air Conditioning (A/C) Inoperative/Intermittent, A/C Blows Warm Air (Replace A/C Low Pressure Cycling Switch) #03-01-39-007 - (May 29, 2003)
2003 Cadillac Escalade, Escalade EXT, Escalade ESV
2002-2003 Chevrolet TrailBlazer, TrailBlazer EXT
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2002-2003 GMC Envoy, Envoy XL
2003 GMC Sierra, Yukon, Yukon XL
2002-2003 Oldsmobile Bravada
2003 HUMMER H2
Condition
Some customers may comment that the A/C system is intermittently inoperative or blows warm air.
Cause
An intermittent inoperative (open) A/C low pressure cycling switch may be the cause. This is an intermittent condition and temperatures may play a critical role if the vehicle is in the failed mode or operating as designed.
Correction
Follow the diagnosis and service procedure below to correct this condition.
Park the vehicle inside or in the shade.
Open the windows in order to ventilate the interior of the vehicle.
If the A/C system was operating, allow the A/C system to equalize.
Turn OFF the ignition.
Open the hood and install fender covers.
Caution
Avoid breathing the A/C Refrigerant 134a (R-134a) and the lubricant vapor or the mist. Exposure may irritate the eyes, nose, and throat. Work in a well ventilated area. In order to remove R-134a from the A/C system, use service equipment that is certified to meet the requirements of SAE J 2210 (R-134a recycling equipment). If an accidental system discharge occurs, ventilate the work area before continuing service. Additional health and safety information may be obtained from the refrigerant and lubricant manufacturers.
For personal protection, goggles and gloves should be worn and a clean cloth wrapped around fittings, valves, and connections when doing work that includes opening the refrigerant system. If R-134a comes in contact with any part of the body severe frostbite and personal injury can result. The exposed area should be flushed immediately with cold water and prompt medical help should be obtained.
Notice
R-134a is the only approved refrigerant for use in this vehicle. The use of any other refrigerant may result in poor system performance or component failure.
To avoid system damage use only R-134a dedicated tools when servicing the A/C system.
Use only Polyalkylene Glycol Synthetic Refrigerant Oil (PAG) for internal circulation through the R-134a A/C system and only 525 viscosity mineral oil on fitting threads and O-rings. If lubricants other than those specified are used, compressor failure and/or fitting seizure may result.
R-12 refrigerant and R-134a refrigerant must never be mixed, even in the smallest of amounts, as they are incompatible with each other. If the refrigerants are mixed, compressor failure is likely to occur. Refer to the manufacturer instructions included with the service equipment before servicing.
Install the J 43600 ACR 2000 Air Conditioning Service Center.
Important
The ambient temperature must be at least 16°C (60°F) .
Do not induce additional air flow across the front of the vehicle during the test.
Record the ambient temperature displayed on the J 43600.
Record readings of the low and high side STATIC pressures. The pressures should be within the specifications listed below.
Above 16°C (60°F): 345 kPa (50 psi)
Above 24°C (75°F): 483 kPa (70 psi)
Above 33°C (90°F): 690 kPa (100 psi)
If the static pressures are within specification, continue with Step 12.
If the static pressures are NOT within specifications, refer to Leak Testing (SI Document ID# 1141201).
Apply the parking brake.
Place the transaxle/transmission in PARK.
Start the engine.
Turn on the A/C system.
Inspect the A/C compressor to see if it is operating properly.
If the compressor is not operating as designed, tap on the low pressure cycling switch (2) with a small hand tool. The compressor should start operating correctly.
If the compressor does not operate correctly after tapping on the low pressure cycling switch (2), disconnect the switch and jumper the lower pressure cycling switch connector with a fused jumper. If the compressor still does not operate properly, refer to HVAC Compressor Clutch Does Not Engage diagnostic in SI.
Important
DO NOT USE A/C low pressure cycling switch, P/N 15035084 on the vehicles listed above.
If the compressor does operate correctly after tapping on the switch or jumping the low pressure cycling switch connector, replace the low pressure cycling switch (2), P/N 89040362. Refer to Air Conditioning (A/C) Low Pressure Switch Replacement in SI.
Perform the Air Conditioning (A/C) System Performance Test in SI.
Disconnect the J 43600 ACR 2000 Air Conditioning Service Center.
Remove the fender covers and close the hood.
Parts Information
Important
Only a small quantity of parts are available. Please DO NOT order for stock only.
Part Number
Description
Qty
89040362
Switch, Pressure Cycling
Parts are currently available from GMSPO.
Warranty Information
Labor Operation
Description
Labor Time
D1180
Switch, Pressure Cycling - Replace
Use published labor operation time
Add
Diagnosis Time
0.0-0.3 hr
Document ID# 976592
HVAC System Inoperative for a Drive Cycle, Poor HVAC System Performance in High Ambient Temperatures (Update HVAC Control Module Software) #02-01-39-005 - (Sep 23, 2002)
HVAC System Inoperative For A Drive Cycle, Poor HVAC System Performance In High Ambient Temperatures (Update HVAC Control Module Software)
Condition
Some customers may comment about no cold air from the heating, ventilation and air conditioning (HVAC) system during a drive cycle. This concern may occur at any time during the drive cycle and at any temperature setting. The HVAC system operation returns to normal after the vehicle has been keyed to off and restarted. This concern is intermittent and most likely to occur on hot days. This concern may be found on vehicles equipped with manual (CJ2) and automatic (CJ3) HVAC systems. Other customers may comment about poor HVAC system performance in high ambient temperature conditions. This concern may be present in automatic (CJ2) HVAC systems only. An HVAC control module software update was put into all production vehicles beginning in September 2002. Vehicles built in September 2002 and earlier may need this software update.
Correction
Update the HVAC control module using software available through GM Access beginning September 9, 2002. The update will be fully available October 7, 2002 to all dealers on TIS 2000 CD version 10. This software update addresses both the intermittent no cooling and the poor performance concerns. If the software update does not correct the concerns, perform the HVAC Diagnostic System Check and repair as necessary. If the HVAC control module is replaced with a part from GMSPO, make sure the module has the latest software update. The module may need to be updated even though it is a new part.
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
D4707
Module or Assembly, HVAC Control Head - Reprogram
0.4 hr
  • 1 year later...
Same problem! Please oh please someone email me with a fix.... I'm pulling what's left of my hair out !!!
[email protected]
Front works great with new compressor, Rear nothing.
If the blower is working ok, then look to either an a/c refrigerant pressure issue (low charge), weak compressor, contaminated refrigerant, blockage of flow in the refrigerant system, or a rear hvac controller or actuator problem.
Check the static (engine OFF) pressure of the a/c's high & low ports, should be around 70 psi at 75* (outside temp), to 100 psi @ 90*. If they read low, then the a/c system has a leak and it will need to be fixed and then re-charged.
If the static pressure seems ok, then I'd look for a temp actuator door problem. You have to remove the rear quarter interior trim panel to access the rear hvac. See if the temp actuator's "drive shaft" moves when turning the temp control from hot to cold. If it moves, but still warm air comes out, there could be either a mechanical problem w/ the actuator door, or the a/c system has a problem w/ refrigerant flow other than a low charge. If it doesn't move, then you'll have to then check for power at the black/white wire at the actuator's harness. Also be sure the black wire has good continuity to ground. If both check out ok, then the actuator may have failed. If no power getting to the actuator, then there may be a problem w/ the controller for the rear hvac. Hope this helps, good luck and keep us updated if you get it fixed.
EDIT: forgot to mention to check the 10 amp IGN 3 fuse, it's only going to have power w/ the keyswitch to RUN.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,326 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
