AC Problem
This one has got me stumpted! There is a clapping noise coming from inside the AC/Heater enclosure, over on the passenger side, just above the foot area. The AC blows cold and seems to be working OK. This is on a 1994, GMC, Suburban, 2500 series with front and rear AC. This problem just started while I was driving down the freeway.
Now it starts clapping at about twice a second when I turn on the ignition and lasts for 20 seconds.....and then it stops! It also starts clapping again when I turn the ignition OFF, and last for 20 seconds! While it is clapping, if I press the MAX (recirculate) button on the AC, it stops for about 5 seconds and starts over again and last for 20 seconds!
The capping noise sounds like it is an actuator door rapidly clapping closed, open, close, open, close, etc. The part that really stumps me is that it does this when I turn the ignition ON or OFF, with the AC ON or OFF!! Doesn't matter.
I have removed the glove box and you have some access to the top of the AC/Heater housing. There are 4 little black boxes (electrical switches, relays) plugged into a bundle of wires that are mounted on top of the AC housing. I have unplugged each of them, one at a time, but the problem is still there.
OK, all you AC experts.......what is the problem and how do i fix it? Thanks, Bill
Is there a possibilty of something caught in the squirrel cage of the blower motor? I had a piece of plastic bag sucked into mine and it drove me crazy until I could figure it out. Does the clapping change with blower motor speed?
No, the blower does not have to be ON at all.....it still claps when I turn the ignition ON...and when I trun the ignition OFF!! :)
Also, I wanted to add that I thought of disconnecting the battery so that the Microprossor that controls all this stuff would reboot and re-program itself.....thinking THAT activity would surely fix the problem. Well, I disconnected the battery for 5 minutes......but it didn't fix the problem!
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 434 Guests (See full list)
