FOR SALE
ersatz
35 Inch PRO COMP ALL TERRAIN tires (4), size LT315 / 75 R16, actual measurements are 34.6” x 12.4”, Load Range D. Less than 2,500 miles, even wear, no blemishes, all tires still retain traces of blue on raised white lettering … $600.00. ALL highway miles - Never used off-road, near excellent condition. Pictures Upon Request. MUST BE PICKED UP IN PERSON. Located just off the New Jersey Garden State Pkwy, exit 58. Call: 609-296-1788, or email me direct…………. [email protected]
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
