Help with GM Part number
I am trying to do a gear swap to 3.73's with all GM parts to ease the bitchin of GM and was given this part number "88966997" for the Ring and pinion set and apperantley the master install kit to.
Can someone verify what comes with this part number before i order it.
I can help ya'....Part #88966997 is called "Gear Kit,Differential Side & Pinion"
It gives you the four gears (two diff.side & two diff.side pinion) and washers that are inside the differential case along with the differential pinion gear shaft and differential pinion gear shaft locking bolt.
It DOES NOT give you the ring & pinion gears.
Also,This kit is for trucks WITHOUT the locking rear differential or "G80".
If you are changing your axle ratio I don't see why you would need this kit.
Hope this helps ya'! :cool:
well there goes that hope, can you give me the part number that i need for the Ring and pinion set, I am looking for the 3.73 ratio
2006 GMC Sierra Extended Cab Short Box
5.3L w/ G80
Currentley have the 3.23 ratio
Sure can,But I'm not at work today so I'll have to get you the number Monday.
Hey,Thanks for the bump,It helped me find your post easier :driving:
Anyway,Part number 12479316 is the 3.73 ratio ring & pinion set for the 8.625 rear-end.
It gives you the ring & pinion gears along with the spacer (AKA "crush sleeve") and lock nut and washer for the pinion gear.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 703 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
